iStoreOS 分区扩容
2024-02-20 12:18:39    维护
原文命令部分转自:iStoreOS x86根分区扩容 - 知乎 (zhihu.com)
因为某些需要,在esxi上面安装了iStoreOS虚拟机,一开始并没有需求,后续有需求才发现overlay分区只有2.5 G空间,远远无法满足,但是又不方便重新安装,故只好查找如何扩容,这里记录一下istoreos内部执行命令。
扩容前提:需要给当前磁盘新增足够空间
# 执行parted
root@iStoreOS:~# parted
# 执行print命令,查看当前分区情况
(parted) print
Model: VMware Virtual disk (scsi)
Disk /dev/sda: 53.7GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      262kB   134MB   134MB   primary  ext2         boot
 2      135MB   403MB   268MB   primary
 3      403MB   2551MB  2147MB  primary  ext4
 4      2551MB  17.2GB  14.6GB  primary  ext4
# 这里对分区3进行扩容,完成后退出
(parted) resizepart
Partition number? 3
Warning: Partition /dev/sda3 is being used. Are you sure you want to continue?
Yes/No? yes
End?  [2551MB]? 53.7G(这里的值根据实际情况进行设定)
(parted) quit
Information: You may need to update /etc/fstab.
# 执行resize2fs对文件系统进行扩容
root@iStoreOS:~# resize2fs -p /dev/sda3
resize2fs 1.46.5 (30-Dec-2021)
Filesystem at /dev/sda3 is mounted on /overlay; on-line resizing required
old_desc_blocks = 1, new_desc_blocks = 7
The filesystem on /dev/sda3 is now 13008704 (4k) blocks long.
# 执行df -h可以看到分区大小已经更新
root@iStoreOS:~# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/sda3                48.8G      1.8G     46.9G   4% /overlay/upper/opt/docker
 1    8476  楼主
回复:iStoreOS 分区扩容
